Ampere Cloud Native Processor solutions
Samsung FIO Installation and Tuning Guide
for Ampere Altra Processors
When designing large-scale, high-performance storage, solution architects often choose to run FIO which is a very common technique that can be used to generate a baseline storage performance for high performance drives. FIO spawns a number of threads or processes doing a particular type of I/O action as specified by the user. FIO takes a number of global parameters, each inherited by the thread unless otherwise parameters given to them overriding that setting is given. The typical use of FIO is to write a job file matching the I/O load one wants to simulate.
This section of the document guides you through the steps that are required to install and tune your FIO performance benchmark.
System Configurations
  • 80 64-bit CPU cores up to 3.30 GHz
  • 64 KB L1 I-cache, 64 KB L1 D-cache per core
  • 1 MB L2 cache per core
  • 32 MB System Level Cache (SLC)
  • 2x full-width (128b) SIMD
  • Coherent mesh-based interconnect
Memory
  • 8x 72-bit DDR4-3200 channels
  • ECC and DDR4 RAS
  • Up to 16 DIMMs and 4 TB addressable memory
Connectivity
  • 128 lanes of PCIe Gen4
  • Coherent multi-socket support
  • 4 x16 CCIX lanes
Technology & Functionality
  • Arm v8.2+, SBSA Level 4
  • Advanced Power Management
Performance
  • SPECrate®2017 Integer Estimated: 300
Altra Platform Configuration
  • Altra 80-core 2P Mt. Jade server
  • 512GB Memory
  • 24x PCIe Gen. 4 Samsung PM1733a SSD drives – 30.72TB
  • Nvme 0-7 on socket 0
  • Nvme 9-24 on socket 1
  • OS: CentOS 8
Ampere Altra Max Processor
  • 128 Arm v8.2+ 64-bit CPU cores up to 3.0 GHz maximum
  • 16 MB System Level Cache (SLC)
  • Coherent mesh-based interconnect – Distributed snoop filtering
Memory
  • ECC, Symbol-based ECC, and DDR4 RAS features 
  • Up to 16 DIMMs and 4 TB/socket
Connectivity
  • 4 x16 CCIX lanes
Performance
SPECrate® 2017_int_base: 359
Altra Max Platform Configuration
  • Altra Max 128-core 2P Mt. Jade server
  • 512GB Memory
  • OS: CentOS 8
System Settings
Grub Setting
iommu.passthrough=1
Numa setting consideration
Need to bind memory and cpu to the correct numa when using 2P platform under tests.
For numa 0:
numa_mem_policy=bind:0 numa_cpu_nodes=0 cpus_allowed=0-127
For numa 1:
numa_mem_policy=bind:1 numa_cpu_nodes=1 cpus_allowed=128-255
PCIe speed and width check
Check link status for all 24x drives to make sure the PCIe speed and width detected correctly.
[root@localhost samsung]# ./LnkSta.sh LnkSta: Speed 16GT/s (ok), Width x4 (ok) LnkSta: Speed 16GT/s (ok), Width x4 (ok) LnkSta: Speed 16GT/s (ok), Width x4 (ok) LnkSta: Speed 16GT/s (ok), Width x4 (ok) LnkSta: Speed 16GT/s (ok), Width x4 (ok) LnkSta: Speed 16GT/s (ok), Width x4 (ok) LnkSta: Speed 16GT/s (ok), Width x4 (ok) LnkSta: Speed 16GT/s (ok), Width x4 (ok) LnkSta: Speed 8GT/s (ok), Width x4 (ok) LnkSta: Speed 16GT/s (ok), Width x4 (ok) LnkSta: Speed 16GT/s (ok), Width x4 (ok) LnkSta: Speed 16GT/s (ok), Width x4 (ok) LnkSta: Speed 16GT/s (ok), Width x4 (ok) LnkSta: Speed 16GT/s (ok), Width x4 (ok) LnkSta: Speed 16GT/s (ok), Width x4 (ok) LnkSta: Speed 16GT/s (ok), Width x4 (ok) LnkSta: Speed 16GT/s (ok), Width x4 (ok) LnkSta: Speed 16GT/s (ok), Width x4 (ok) LnkSta: Speed 16GT/s (ok), Width x4 (ok) LnkSta: Speed 16GT/s (ok), Width x4 (ok) LnkSta: Speed 16GT/s (ok), Width x4 (ok) LnkSta: Speed 16GT/s (ok), Width x4 (ok) LnkSta: Speed 16GT/s (ok), Width x4 (ok) LnkSta: Speed 16GT/s (ok), Width x4 (ok) LnkSta: Speed 16GT/s (ok), Width x4 (ok)
Max Read Request needs set to 512 bytes
[root@localhost samsung]# ./mrr.sh MaxPayload 512 bytes, MaxReadReq 512 bytes MaxPayload 256 bytes, MaxReadReq 512 bytes MaxPayload 512 bytes, MaxReadReq 512 bytes MaxPayload 256 bytes, MaxReadReq 512 bytes MaxPayload 512 bytes, MaxReadReq 512 bytes MaxPayload 256 bytes, MaxReadReq 512 bytes MaxPayload 512 bytes, MaxReadReq 512 bytes MaxPayload 256 bytes, MaxReadReq 512 bytes MaxPayload 256 bytes, MaxReadReq 512 bytes MaxPayload 512 bytes, MaxReadReq 512 bytes MaxPayload 256 bytes, MaxReadReq 512 bytes MaxPayload 512 bytes, MaxReadReq 512 bytes MaxPayload 256 bytes, MaxReadReq 512 bytes MaxPayload 512 bytes, MaxReadReq 512 bytes MaxPayload 256 bytes, MaxReadReq 512 bytes MaxPayload 512 bytes, MaxReadReq 512 bytes MaxPayload 256 bytes, MaxReadReq 512 bytes MaxPayload 512 bytes, MaxReadReq 512 bytes MaxPayload 256 bytes, MaxReadReq 512 bytes MaxPayload 512 bytes, MaxReadReq 512 bytes MaxPayload 256 bytes, MaxReadReq 512 bytes MaxPayload 512 bytes, MaxReadReq 512 bytes MaxPayload 256 bytes, MaxReadReq 512 bytes MaxPayload 512 bytes, MaxReadReq 512 bytes MaxPayload 256 bytes, MaxReadReq 512 bytes
Precondition the drives
Prior to using the drives and running benchmark, you need to format, then precondition all the drives.
Random Read/Write Configuration for 24 Samsung PM1733a SSDs
Random Read
[global] name=random rw=randread bs=4K direct=1 numjobs=16 runtime=600 ioengine=libaio iodepth=64 norandommap group_reporting randrepeat=1 random_generator=tausworthe64
Random Write
[global] name=randomwrite rw=randwrite bs=4K direct=1 numjobs=16 ramp_time=20 runtime=600 ioengine=libaio iodepth=64 norandommap group_reporting randrepeat=1 random_generator=tausworthe64
Sequential Read/Write Configuration for 24 Samsung PM1733a SSDs
Sequential Read
[global] name=sequence rw=read bs=128K direct=1 numjobs=4 runtime=600 ioengine=libaio iodepth=64 norandommap group_reporting randrepeat=1 random_generator=tausworthe64
Sequential Write
[global] name=sequence rw=write bs=128K direct=1 numjobs=4 runtime=600 ioengine=libaio iodepth=64 norandommap group_reporting randrepeat=1 random_generator=tausworthe64
Samsung PM1733a FIO Performance on Ampere Altra
Random Read/Write (MBps), bs=4k, jobs=16, iodepth=64, 10min
Sequential Read/Write (MBps), bs=128k, jobs=4, iodepth=64, 10min
CPU Utilization (%)
Samsung PM1733a FIO Performance on Ampere Altra Max
Random Read/Write (kIOPS), Altra Max
Sequential Read/Write (MBps), Altra Max
CPU Utilization (%)
Samsung PM1733a FIO Performance on Ampere Altra vs. Altra Max
Random Read (klOPS), Altra vs. Altra Max
CPU Utilization of Random Read, Altra vs. Altra Max
September 2026
Ampere® PMU Profiler: A Guide to Microarchitectural Performance Analysis
Created At : April 18th 2023, 11:02:13 am
Last Updated At : December 19th 2024, 6:05:11 pm
