Ampere Cloud Native Processor solutions
Azure: How to Guide
Tutorial
A simple 'How to Guide' to assess, evaluate, test and optimize Ampere Altra Cloud Native Processors on Microsoft Azure.
Learn
Learn about the Ampere Altra Processor,
  • value proposition, and technical documentation
https://amperecomputing.com/products/processors
https://amperecomputing.com/solutions/azure?referrer=azure
Assess
Do an inventory of your software stacks
  • Study types of applications (open/closed source)
  • Check for aarch64 support (Compilers, JDK etc.)
Evaluate software readiness via Ampere Ready Software: https://amperecomputing.com/solution
Assess your stack readiness using workload briefs: https://amperecomputing.com/developer
System test drive options at: https://amperecomputing.com/where-to-try
Build
Build using newer versions of available compilers (gcc, clang, etc.)
  • Runtime languages like Java are easier to transition.
  • Aarch64 container images for most applications readily available
What does it take to build PostgreSQL (Large complex application, and among the top 5 databases in use) on Arm64?
git clone https://github.com/postgres/postgres.git cd postgres ./configure --with-openssl CFLAGS= "-mcpu=native" make -j sudo make install
Five lines of code!
Test and Optimize
validate against your usual test suites.
  • Use performance tuning guides on Ampere Developer center.
  • Study performance scaling under load and SLA
Tools used – the same as on x86 perf, sysstat, eBPF, etc.
Tuning Guides: https://amperecomputing.com/tuning-guides
Deploy
For feedback, contact: developer@amperecomputing.com
Ampere Ready Software- make it Azure specific software ready!Developer CenterNeed more information?
Try out our free trial platforms. Find the system best suited for your workload needs and get started developing today.We make it easier to design, build, and deploy cloud applications with resources, technical documentation, and guides.We’re here to answer your questions and get you started on the road to sustainability in your data center or on the edge.
Where to TryJoin the CommunityContact Us
May 2025
Created At : June 21st 2023, 9:10:29 am
Last Updated At : September 8th 2026, 7:05:37 pm
