Executive Summary
The Ampere® PMU Profiler (APP) is a Python-based tool designed to provide deep insight into the microarchitectural behavior of applications running on Ampere CPUs (e.g., Ampere® Altra® and AmpereOne®). Unlike standard profilers that identify where time is spent (for example, which functions consume CPU time), the PMU Profiler explains why time is being spent by measuring low-level hardware events associated with the CPU pipeline and execution behavior.
A key outcome of APP is that it enables performance engineers to move from coarse symptoms to actionable causes. For example, while application-level profiling can show an expensive code path, APP can help identify whether the expense stems from inefficient instruction fetching, data cache misses, or other microarchitectural factors that are difficult or impossible to isolate using application-level tools alone. The document outlines a top-down performance analysis methodology and positions APP as an essential final step for expert-level tuning, particularly on Ampere platforms, where you must understand hardware-level bottlenecks and then apply targeted code optimizations.
APP is intended to complement system-level analysis rather than replace it. System-level profilers are useful for identifying high-level bottlenecks such as resource saturation or contention, but APP is focused on microarchitecture-level analysis by collecting hardware events. This makes APP especially valuable after system bottlenecks have been eliminated or ruled out, leaving “microarchitecture inefficiency” as the remaining likely cause of slowdowns
What is the Ampere PMU Profiler?
The Ampere PMU Profiler uses Linux perf utility with validated pmus and metrics on Ampere CPUs. Its purpose is to capture microarchitectural performance indicators through hardware event measurement. In practice, this means APP collects events measured by perf stat that relate to the CPU pipeline and execution mechanisms, allowing engineers to determine not only what is slow, but the underlying microarchitectural reason.
A central distinction between APP and application profiling tools is the level of visibility. Tools that sample stack traces (or count function invocations) typically answer: “Which functions are active during the slow period?” APP answers a more hardware-specific question: “Which microarchitectural mechanisms are consuming cycles, and what stalls or inefficiencies are present?”
The APP workflow assumes that developers can form a hypothesis about where the bottleneck likely originates, such as a particular loop or data access pattern and then rely on PMU event measurements to confirm or refute those hypotheses at the microarchitectural level
Why Do We Need APP?
Performance problems are frequently multi-layered. Even after system-level bottlenecks are addressed (for example, ensuring that CPU is not idling due to I/O, ensuring there is sufficient memory, and verifying resource utilization), some workloads still perform poorly because the CPU spends cycles in inefficient pipeline states.
APP helps solve this class of problems by measuring hardware-level behavior. For example, APP can identify microarchitectural bottlenecks such as:
  • inefficient instruction fetching,
  • data cache misses,
  • branch-related pipeline effects,
  • and other pipeline-level stall sources that manifest as lost cycles.
This capability is important because microarchitectural causes often do not map cleanly to application symptoms. Code can appear “hot” in a profiler, but the reason it is slow might be due to how it interacts with cache hierarchies, how it causes translation or fetch inefficiencies, or how the processor recovers from pipeline disruptions. Those details are what PMU-based measurement aims to expose.
APP also links investigation to “unlocking the full performance potential” of the hardware. By understanding CPU-level bottlenecks, engineers can choose targeted optimizations that application-level tools alone cannot determine with confidence. This ultimately leads to more efficient software and better utilization of Ampere hardware for competitive workloads
When Do We Use the Ampere PMU Profiler?
Understanding the APEX framework
Performance tuning is a process of systematic investigation, moving from a broad, system-wide view down to the specific interactions between code and hardware. 
funnel-graphic.png Fig. 1: The Adaptive Profiling and Execution (APEX): Benchmarking & Optimization Funnel
Performance Optimization is as much art as it is science. The APEX framework uses tools and methodologies to add structure and rigor to the process and can bridge the gap between creative intuition and empirical fact.
We propose applying the APEX (Adaptive Profiling and Execution) methodology to enable root cause analysis for solving performance problems. Follow the funnel above from top to bottom to effectively use the procedure.
The methodology recommends starting with assessing platform health as a first step to ensure that platform used for performance analysis is set up well. An unhealthy platform may mislead the performance analysis.
Consider capturing initial performance metrics before tuning any system or application settings. This establishes a clear understanding of the current workload and identifies key scalability knobs. We recommend using Ampere’s PerfKit Benchmarker (APB), which supports many open-source applications, to create a reliable baseline for further analysis and tuning.
Next, is to assess system performance and any hardware or system bottlenecks while the code is – this is where Ampere System Profiler (ASP) is useful to eliminate any system or resource bottlenecks. ASP can also be used to right-size the instance shape and ensure that the compute resources are efficiently consumed by the workload.
One method which may be used is to leverage APB’s automated benchmarking framework to start and stop ASP’s collectors during run phase of a given APB benchmark. This ensures that profile is collected while critical code paths are executed and clear report profile is generated.
Once system and resource bottlenecks are eliminated, if the performance issue persists and points to CPUcycles not being used efficiently, we propose going to the next step in the pyramid and use Ampere PMU Profiler to root-cause the issue further.
Finally, system benchmarking should be done after all bottlenecks are resolved or analyzed to effectively measure the system’s performance for the workload.
Following this systematic APEX methodology ensures that we eliminate possible issues as a part of a structured process to efficiently conduct root cause analysis.[
System-Level Analysis
At the microarchitecture level, performance is shaped by how the CPU pipeline handles instruction delivery, execution, and memory access. APP leverages PMU measurements to identify pipeline behavior and stall sources.
Memory hierarchy and performance loss
APP emphasizes the performance significance of the memory hierarchy. As data access moves from registers to L1 cache, then L2 cache, then L3 cache, and finally DRAM, access becomes exponentially slower. Because of this, cache misses are a primary cause of performance loss. This provides a conceptual foundation for many APP investigations: if a workload touches large working sets or accesses data in a non-contiguous pattern, it may trigger cache misses that increase effective latency and reduce throughput.
Microarchitectural bottleneck identification
APP can be used at the microarchitecture level to understand where stalls might be in the pipeline. The APP role is to collect hardware events related to pipeline stall behavior and to use those events to characterize the workload’s execution profile. This capability matters because pipeline stalls and inefficiencies can dominate runtime even when application-level profiling points to a “hot” function without explaining the root cause.
Key Questions:
APP is structured around answering questions that cannot be fully resolved with application-level profiling alone. Based on the described APP workflow and report interpretation strategy, APP can help you answer:
1. Where are cycles going at the microarchitectural level? The APP HTML report and TDA sunburst charts are used to broadly characterize whether time is dominated by categories such as instruction retirement behavior, frontend bound behavior, or backend bound behavior.
2. Which stall or inefficiency class is consistent with the hot code path? Once you hypothesize a bottleneck mechanism (e.g., cache misses from non-contiguous access), APP measurements can confirm whether the observed behavior aligns with that mechanism.
3. What microarchitectural reason explains a hot function’s cost? APP’s purpose is explicitly to explain why time is spent by measuring hardware events. This allows developers to translate hot functions into hardware interactions that can be optimized.
4. Is the workload limited by instruction delivery versus execution/memory? By inspecting broad characterization categories (frontend vs backend bound) in the APP HTML report, engineers can determine which side of the pipeline is more likely to be limiting performance.
Example usage and Output:
app -n 120 -c 1,2 -i 1 –tda -o <folder> -j “taskset -c1,2 <workload>
The above example command attempts to collect:
  • PMU profiling samples for 120s
  • With a sampling interval of 1s
  • Profiles on cores 1 and 2
  • TopDown metrics and render TDA sunburst chart
  • PMU profiles while running the workload affinitized to cores 1 and 2.
Metrics reported by APP:
Metric Name
Description
IPC
Instructions retired per CPU cycle (user + kernel   unless separated).
IPC_kernel
Instructions retired per CPU cycle while executing   in kernel/EL1.
cpu_freq
Average core frequency during the measurement   interval (typically in GHz or MHz).
#Cycle_Accounting Metrics
frontend_bound
Fraction of cycles where retirement is limited by   the front-end (fetch/branch prediction/decode/ICache/ITLB/queueing).
backend_bound
Fraction of cycles where retirement is limited by   the back-end (execution resources, cache/memory   latency/bandwidth, ROB/LSQ pressure).
#Branch_Effectiveness Metrics
branch_mispredict%
Percent of retired branch instructions that   were mispredicted (causing pipeline recovery/flush).
branch_mpki
Branch mispredictions per 1,000 instructions   retired.
#DTLB_Effectiveness Metrics
dtlb_mpki
Data TLB misses per 1,000 instructions retired   (that require translation refill/walk beyond L1 DTLB).
dtlb_walk%
Percent of DTLB misses that trigger a page-table   walk (vs. being satisfied by a next-level TLB).
l1d_tlb_miss%
L1 DTLB miss rate (L1 DTLB misses divided by DTLB   accesses).
l1d_tlb_mpki
L1 DTLB misses per 1,000 instructions   retired.
l2_tlb_miss%
L2/second-level DTLB miss rate (misses divided by   L2 TLB accesses).
l2_tlb_mpki
L2/second-level DTLB misses per 1,000 instructions   retired (typically correlates with page walks).
#ITLB_Effectiveness Metrics
itlb_mpki
Instruction TLB misses per 1,000   instructions retired.
itlb_walk%
Percent of ITLB misses that trigger a page-table   walk (vs. hit in a next-level TLB).
l1i_tlb_miss%
L1 ITLB miss rate (misses divided by ITLB   accesses).
l1i_tlb_mpki
L1 ITLB misses per 1,000 instructions   retired.
#L1_Cache_Effectiveness Metrics
l1i_mpki
L1 instruction cache misses per 1,000 instructions   retired.
l1d_mpki
L1 data cache misses per 1,000 instructions   retired.
l1i_miss%
L1 instruction cache miss rate (misses /   accesses).
l1d_miss%
L1 data cache miss rate (misses / accesses).
#L2_Cache_Effectiveness Metrics
l2_mpki
L2 cache misses per 1,000 instructions retired   (typically demand misses; exact scope depends on event mapping).
l2_miss%
L2 cache miss rate (misses / L2 accesses).
l2d_inv_pki
L2 data cache invalidations per 1,000 instructions   (coherency-driven invalidations affecting this core/cluster).
l2_snoops_pki
L2 snoop transactions per 1,000 instructions   (coherency probes observed/handled).
l2d_inv_per_snoop
Average invalidations generated per snoop   (invalidation intensity per probe).
#Operation_Mix Metrics
branch_percentage
Percent of retired instructions that are branch   instructions.
crypto_percentage
Percent of retired instructions that are   crypto/CRC/hash-class instructions (Arm crypto extensions).
integer_dp_percentage
Percent of retired instructions that are integer   data-processing (ALU) operations.
load_percentage
Percent of retired instructions that   are loads.
store_percentage
Percent of retired instructions that   are stores.
scalar_fp_percentage
Percent of retired instructions that are scalar   floating-point operations.
simd_percentage
Percent of retired instructions that are SIMD/NEON   (vector) operations.
#Pipeline_Stall_Frontend
stall_frontend_cache_rate
Fraction of cycles stalled due to instruction-side   cache/fetch delivery issues (e.g., I-cache   misses/linefill effects).
stall_frontend_tlb_rate
Fraction of cycles stalled due to   ITLB/translation-related front-end stalls.
stall_recovery_rate
Fraction of cycles spent recovering from pipeline   flushes (commonly branch mispredict recovery and similar   redirects).
stall_fronetend_bob_rate
Fraction of cycles stalled because the front-end   buffer/queue (often “branch/order buffer” or fetch/decode buffering) is   full/blocked, limiting delivery to the back-end.
#Pipeline_Stall_Backend
stall_backend_cache_rate
Fraction of cycles stalled due to cache hierarchy   latency on the data side (L1D/L2/SLC effects excluding pure DRAM   bandwidth).
stall_backend_tlb_rate
Fraction of cycles stalled due to DTLB   misses/page-walk latency impacting loads/stores.
stall_backend_mem_rate
Fraction of cycles stalled due   to main-memory/DRAM latency or bandwidth limits (off-chip).
stall_backend_core_rate
Fraction of cycles stalled due to core execution   limits (e.g., dependency chains, execution-unit throughput).
stall_backend_resource_rate
Fraction of cycles stalled due to internal resource   pressure (queues, buffers, credits) not attributed to a specific   unit.
stall_rob_id_rate
Fraction of cycles where progress is limited by   reorder buffer / in-flight instruction capacity (ROB full / cannot   dispatch/retire).
stall_ixu_sched_rate
Fraction of cycles stalled due to integer execution   scheduler/issue queue pressure (IXU scheduling bottleneck).
stall_fsu_sched_rate
Fraction of cycles stalled due to FP/SIMD execution   scheduler/issue queue pressure (FSU scheduling bottleneck).
stall_lob_id_rate
Fraction of cycles stalled due to load buffer/queue   (load-order/load buffer) being full or blocked.
stall_sob_id_rate
Fraction of cycles stalled due to store   buffer/queue (store-order/store buffer) being full or blocked.
#uncore metrics
slc_miss%
System-level cache (SLC/LLC) miss rate for requests   reaching SLC (misses / accesses).
mc_retry_rate%
 Percent of memory-controller transactions that are   retried (e.g., due to contention/queue   full/flow-control), indicating fabric/MC pressure
Estimated DRAM read bandwidth consumed   (GB/s).
memrd_bw_GBps
Estimated DRAM write bandwidth consumed   (GB/s).
memwr_bw_GBps
CCIX (coherent interconnect) inbound bandwidth to   the socket/system (MB/s).
ccix_in_bw_MBps
CCIX outbound bandwidth from the socket/system   (MB/s).
ccix_out_bw_MBps
Refer to a detailed Tuning Guide Here
Conclusion
The APP enables PMU hardware event measurement to provide microarchitecture-level performance insight on Ampere CPUs. It is designed to answer the “why” behind performance problems by identifying microarchitectural causes such as inefficient instruction fetching and data cache misses, which are difficult to detect through application-level profiling alone.
The APP workflow is top-down and hypothesis-driven: form a hypothesis from the hot function, measure with APP profiles, then analyze using the APP HTML report with TDA sunburst charts to characterize where cycles are being spent (instruction retirement, frontend bound, backend bound). APP is most valuable when system-level bottlenecks have been characterized or ruled out and microarchitecture-level explanation is required for expert tuning.
September 2026
Ampere® Perfkit Benchmarker (APB) Tutorial
Created At : August 5th 2026, 5:26:36 pm
Last Updated At : August 11th 2026, 9:07:05 pm
